araghava
Apr 28, 2020Star
MK63 question
I just installed MK 63. When I look at the system by logging in from my desktop I correctly see 2 satellites. 1 wired and 1 wireless. However the app on my iPhone says there is only one sattelite...
araghava
May 01, 2020Star
HI Christian,
Thanks for responding. Yes, when I login from my desktop it shows 1 wired and 1 wireless.
However the iPhone app only shows one satellite. As I mentioned in my post when I go to the network map in the iPhone app it shows 1` attelite with a green dot and then a dotted line to another satellite with a pink dot. What does the dotted line mean and what does the pink dot mean.
Christian_R
May 01, 2020NETGEAR Employee Retired
Hi araghava,
May you let me know the current app version your phone is on (iOS or Android).
Thanks,
Christian
- araghavaMay 01, 2020Star
IPhone: 2.4.24.1
