DeveshNatalia
May 14, 2022Aspirant
MK63 (router and satellite)
Over the last 2 weeks I have been experiencing dropouts and high latency across my mesh network. After speaking with Netgear support, my router firmware version is 1.1.1.122 and both satellites are...
May 14, 2022Guru - Experienced User
did you try upgrading the routers firmware?
Nighthawk MR60 | WiFi 6 System | NETGEAR Support
What modem/gateway is it connected to?
Does it happen to both wired and wireless device? Or just wireless?
- DeveshNataliaMay 15, 2022Aspirant
The MR and MS are now all on the same version 1.1.6.124 but am still getting intermittent timeouts and high latency. This is only a problem on the wireless using the Netgear MR and MS mesh AP's, wired or wireless connection into my BT modem is absolutely fine.
- plemansMay 15, 2022Guru - Experienced User
Is your bt modem in router mode? if so, it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode- DeveshNataliaMay 16, 2022Aspirant
I've put the netgear system into AP mode. can you confirm which firmware i should be using across all of the devices?
