Rsamp
Mar 05, 2025Aspirant
MK63 Verizon ISP provided new router to install
My ISP (VerizonFios) mandates that I install their new updated router. My Nighthawk MK63 is currently connected to the old Verizon router. Is there anything I need to do to connect my Nighthawk to ne...
- Mar 05, 2025
Yes.
Mar 05, 2025Guru - Experienced User
The model string of the MK63 router unit. The satellites are MS.
Rsamp
so, the Main Router that has the Ethernet cable plugged into Verizon router?
If so since previous router was configured to work with Nighthawk I most likely just need to plug in and set up like I did with original? Is that what I'm hearing?
- FURRYe38Mar 05, 2025Guru - Experienced User
Yes.
- RsampMar 05, 2025Aspirant
Furrye38
Thanks so much for you help. It was nothing more than changing out the original router and replugging in all the cables as I had hoped. Your links were helpful too.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
