Rsamp
Mar 05, 2025Aspirant
MK63 Verizon ISP provided new router to install
My ISP (VerizonFios) mandates that I install their new updated router. My Nighthawk MK63 is currently connected to the old Verizon router. Is there anything I need to do to connect my Nighthawk to ne...
- Mar 05, 2025
Yes.
Rsamp
so, the Main Router that has the Ethernet cable plugged into Verizon router?
If so since previous router was configured to work with Nighthawk I most likely just need to plug in and set up like I did with original? Is that what I'm hearing?
Mar 05, 2025Guru - Experienced User
Yes.
- RsampMar 05, 2025Aspirant
Furrye38
Thanks so much for you help. It was nothing more than changing out the original router and replugging in all the cables as I had hoped. Your links were helpful too.
- FURRYe38Mar 05, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
