RJSteck
Mar 21, 2022Follower
MK63 with dual wired backhaul
Looking through the other discussions, the topic is not quite fully addressed. So, asking specifics.
If using an unmanaged switch to expand the MR60 direct connections to the 2 MS60.... do I need to do anything besides plug them in.?
Ie, Modem <> MR60 <> 1G switch <> MS60 (x2)...?
Do I setup both the MS60 wirelessly as described in the documentation, then just plug in the cat 6...?
THANKS
1 Reply
You should just be able to plug them in.
If your just using an unmanaged switch, its pretty simple/easy/fast.
