tchrisman
Jan 22, 2022Aspirant
MK63S Blocked sites and applications
Purchased a MK63S Router (MR60) and two satellites (MS60). Having problems with sites being blocked, or being unresponsive and apps on smart tvs not allowed to pass traffic, or limited traffic. Also ...
michaelkenward
Jan 23, 2022Guru - Experienced User
tchrisman wrote:
If I buypass the router, no problems connecting to sites and services.
What router is that? The MR60 or something else in front of it?
While many issues are generic and can be dealt with anywhere, in this case you are asking about things that are specific to your Mesh hardware rather than the Nighthawk WiFi Routers covered in this section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
tchrisman
Jan 23, 2022Aspirant
Thanks. I have looked around but I will try again. I appreciate your help.
- michaelkenwardJan 23, 2022Guru - Experienced User
You did not answer my question.
It may be important.
- tchrismanJan 30, 2022Aspirant
MR60 with two MS60 Sats
