russellwhite
Mar 30, 2023Tutor
MK63S not showing devices
 I have an MK63S with two satellites. When I look for connected devices either on the Nighthawk app or via a web browser, none of the connected devices show up. They are all on firmware version 1.1.7....
- Mar 31, 2023It could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
michaelkenward
Mar 30, 2023Guru - Experienced User
Showing up where:
- Mobile app?
- Browser graphical user interface (GUI)?
This is a good alternative for Windows and Macs:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress and install.
Netgear is trying to kill this useful utility.
- russellwhiteMar 30, 2023TutorThat was in the original message. Both the app and the browser show 0 connected devices. - plemansMar 31, 2023Guru - Experienced UserIt could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
