russellwhite
Mar 30, 2023Tutor
MK63S not showing devices
 I have an MK63S with two satellites. When I look for connected devices either on the Nighthawk app or via a web browser, none of the connected devices show up. They are all on firmware version 1.1.7....
- Mar 31, 2023It could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
michaelkenward
Mar 30, 2023Guru - Experienced User
Showing up where:
- Mobile app?
- Browser graphical user interface (GUI)?
This is a good alternative for Windows and Macs:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress and install.
Netgear is trying to kill this useful utility.
russellwhite
Mar 30, 2023Tutor
That was in the original message. Both the app and the browser show 0 connected devices.
- plemansMar 31, 2023Guru - Experienced UserIt could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
