Snowy-Owl
Dec 03, 2023Guide
MK73 Broken mDNS / Bonjour / SDDP / UPnP / DLNA
Hello, I would like to report a bug in the latest firmware for the MK73 1.0.3.34 and 1.0.3.32 If I upgrade to these firmware versions I lose mDNS, Bonjour, SDDP, UPnP and DLNA device access on my ...
Dec 04, 2023Guru - Experienced User
Had a Factory reset performed after loading v1.0.3.34 on the system to see if this cleared the behavior?
- Snowy-OwlDec 04, 2023Guide
Factory reset does not resolve the issue.
- FURRYe38Dec 05, 2023Guru - Experienced User
Have you opened a support ticket with NG support?
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".Reference this forum thread as well.
- Snowy-OwlDec 05, 2023Guide
Just sent a support email, hope they will fix the firmware.
