in2ndo
Jul 24, 2021Apprentice
MK80 and OpenDNS
Hello, Has anyone been able to change the DNS numbers to OpenDNS on a MK83 ? the option to change it is there. but the number fields remain greyed out. Thanks.
Aug 03, 2021Guru - Experienced User
Disable Armor before trying to change any DNS.
What browser are you using to change the settings? Try MS Edge, Firefox or Opera.
Be sure to clear out all broswer caches before entering the routers web page.
in2ndo
Aug 03, 2021Apprentice
I’ll try that. But since I was already able to change the numbers to openDNS and setup the DDNS service with noIP. Shouldn’t the router be updating the IP to the noIP account?
When I check the status within the routers page. It updates fine. But if I change the iP on the noIP account webpage as instructed by noIP (to test it) and restart the router. Is not getting updated on the noIP account.
And I’m using safari and chrome.
