notabot
Aug 25, 2021Aspirant
MK83 – satellite drops internet for all clients, but internet status = good
Vexing problem and would love help – here's the rundown: Brand new MK83 mesh system Clients on satellite get strong internet speed test results (when it works) – ~80 - 110 Mbps Clients on satelli...
Aug 25, 2021Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
notabot
Aug 29, 2021Aspirant
Thanks for the help FURRYe38.
I monitored the internet uptime using a simple chrome extension on both satellites and saw that the time of short outages seemed to be synced up. So then I monitored the wifi router and a sattelite and that also had outages happening at roughly the same time. To rule out a bad modem, I picked up a new CM1100 at Costco yesterday.
I have still seen small outages on the wifi network, based on the connection monitor log, but I haven't been able to monitor the modem to see if that is also getting the same dropped connections.
At the end of the day, it seems like the mesh network might not be the issue. However, it's still odd to have the wifi router report that the internet connection status is good when there is no working internet.
Thanks again for your help with troubleshooting.
- FURRYe38Aug 30, 2021Guru - Experienced User
Let give feedback to the questions presented so we can better get an idea of your configuration.
