IsheeR
Apr 20, 2023Aspirant
MK83 - Satellite Will Not Connect
I have a "NETGEAR Nighthawk Tri-band Whole Home Mesh WiFi 6 System (MK83) - AX3600 Router with 2 Satellite Extenders, Coverage up to 6,750 sq. ft. and 40+ devic" system and 1 addon MS80 satellite. ...
- Apr 28, 2023
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
IsheeR
Apr 21, 2023Aspirant
Hi FURRYe38,
Great suggestion. I did as you described. I was able to access the addon satellite while hard wired and it has the same firmware version as the rest of the devices which is the latest version (1.1.7.12). Should I try reinstalling the firmware on the satellite or is there something else I should try next? Thanks for your help!
Apr 21, 2023Guru - Experienced User
Latest is v.14:
I would get these files downloaded first, update ALL MS first by directly uploading the MS FW file to the MS web page, then update the MR lastly.
- IsheeRApr 21, 2023Aspirant
Ah, the update checker wasn't finding this new version. I went ahead and downloaded the updates and updated each device manually. I don't have physical access to the equipment at the moment but will disconnect the addon satellite from hardwire and see if it syncs up. I'll be back in touch. Thanks again!
