IsheeR
Apr 20, 2023Aspirant
MK83 - Satellite Will Not Connect
I have a "NETGEAR Nighthawk Tri-band Whole Home Mesh WiFi 6 System (MK83) - AX3600 Router with 2 Satellite Extenders, Coverage up to 6,750 sq. ft. and 40+ devic" system and 1 addon MS80 satellite. ...
- Apr 28, 2023
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
IsheeR
Apr 28, 2023Aspirant
The trouble satellite did eventually sync up a few hours after the firmware update without having to reset the router. Thanks for all of your help with my issue!
Apr 28, 2023Guru - Experienced User
Enjoy. 📡
- IsheeRApr 28, 2023Aspirant
Great advice! Thanks again for all of your help!
