djpaoli
Jul 14, 2021Guide
MK83 Backwards compatibility
I have the MK63 system and would like to switch to the MK83 system and use the two MS60 satellites from the MK63 system in my new configuration MK83. My question is if they are compatible with the MK83 system or not. Will I have a problem setting them up?
Not sure.
Maybe Christian_R knows.
- Christian_RNETGEAR Employee Retired
Hello djpaoli,
We have an article for more info regarding this. I've linked it below.
Christian
- djpaoliGuideThanks for reply.
I bought the MK83 system and configured the two MS60 satellites from my previous system to work with the new one but they are disconnected from and connected all the time, not getting a stable connection.
All devices are updated with firmware V1.1.4.6.
I'm about to give up and switch to another system.- plemansGuru - Experienced User
Do the stock satellites that came with the system work fine?
How far from the router are the MS60 satellites?
What materials is the home made from?
