xeddog
Oct 22, 2022Aspirant
MK83 defined as AP has orange light.
I have recently installed the nighthawk MK83 WiFi mesh. The configuration I wanted was probably WAY out of the norm since I wanted the WiFi devices to have IP addresses on a Class A 10 net. This ...
Oct 23, 2022Guru - Experienced User
Log into it. It wouldn't be the first time a device has had a firmware update and reset back to factory. Or switched back to router mode.
- xeddogOct 23, 2022Aspirant
Thank you for the reply.
I updated to latest firmware right after installation, so it is current. I just double checked the Netgear website and it is still the current version. I rebooted anyway just because, and the light is still amber. The lights on the MS80 devices have blue lights so it's only the MR80.
Since everything is running great, I am going to assume this is a gigantic ghost in the machine (aka bug) and the world is going to end soon. đ Either that, or a very minor bug that is only annoying. Probably the latter.
