xeddog
Oct 22, 2022Aspirant
MK83 defined as AP has orange light.
I have recently installed the nighthawk MK83 WiFi mesh. The configuration I wanted was probably WAY out of the norm since I wanted the WiFi devices to have IP addresses on a Class A 10 net. This ...
Oct 23, 2022Guru - Experienced User
How is the MR connected to the host router? Using the WAN or LAN port on the MR?
What FW is loaded on the MESH system?
What CAT# lan cable are you using?
