xeddog
Oct 22, 2022Aspirant
MK83 defined as AP has orange light.
I have recently installed the nighthawk MK83 WiFi mesh. The configuration I wanted was probably WAY out of the norm since I wanted the WiFi devices to have IP addresses on a Class A 10 net. This ...
xeddog
Oct 23, 2022Aspirant
The MR is connected using the "Internet" port via a 25ft Cat5 cable to a Netgear ProSafe JGS516PE switch. That switch is connected to my ASUS RT-AC5300 router via Cat 5E cable which is a bit long at around 50ft when the two devices are right next to each other. That router is, of course, connected to my cable modem which is in Bridge mode.
I just moved the cable on the MR to one of the other ports and rebooted. No change.
Firmware is V1.1.7.12_3.1.108
Oct 23, 2022Guru - Experienced User
Try connecting the MR directly to the host router bypassing this switch.
CAT6 is recommended. CAT5 is not rated for 1000Mbps.
- xeddogOct 23, 2022Aspirant
MR80 was moved from the switch to the ASUS router. No change. Regarding the cables, I have some cat6 cables somewhere. My house is in quite a state of disarray for now (long story), but I do have some cat6 cable and connectors, so I can make them if necessary.
