Agriffo13
May 03, 2025Aspirant
MK83 Factory reset
I have tried performing a factory reset directly from the router and through the admin settings from a connected pc. Once it reboots, the router settings and name remains. Any suggestions? Anyone else...
May 06, 2025Guru - Experienced User
Have you tried the old 30-30-30 reset?
push and hold reset for 30 seconds while powered on, keep holding reset and power it off for 30 seconds, power it back on while still holding reset fo 30 seconds
