Andy_Shiekh
Dec 02, 2025Aspirant
MK83 firmware 1.1.8.20 problems
MK83 firmware 1.1.8.20 came out yesterday (Dec 1st 2025) and I find the satellite keeps disconnecting. Restoring to version 1.1.7.14 fixes the issue. Anyone else seeing this?
Andy_Shiekh
The router first than the satellites (both manually).
All units are separated by more than 30 feet and all was fine initially, but then I started noticing a satellite disconnecting periodically.
Am back on 1.1.7.14 and see no problems and the units make no attempt to update automatically.
- FURRYe38Dec 03, 2025Guru - Experienced User
MS need to be updated FIRST, then the MR lastly.
A factory reset should be performed as well after new FW has been loaded.
