joggy64
Aug 26, 2021Tutor
MK83 firmware updates
Hi - my MK83 router and satellites have been running on firmware version 1.1.4.6 since I originally setup this mesh network back in May. I check for updates monthly via the web interface(ADVANCED>Adm...
- Aug 26, 2021
If you don't see any web page option to opt out or disable auto FW upates, then NG maybe running the MK series like Orbi systems where the system auto updates when NG chooses to release new FW. Something users don't have any control over. Been like this for a while and NG doesn't seem to change it.
Aug 26, 2021Guru - Experienced User
I don't have that system and not many that help on here do. (so can't check one of my own devices)
I know on the orbi's you can't disable auto-updates anymore but I'm not sure about the mk system.
maybe ChristineT or DarrenM know more.
- joggy64Aug 26, 2021Tutor
Thanks pleamans. I'll see if Christine or Darren chime in.
- FURRYe38Aug 26, 2021Guru - Experienced User
Yeah I definitely didn't see an option to control that. I understand why they would want to auto update these devices, but it's unfortunate users can't opt out/turn off that functionality.
Knowing that the Orbi software functions this way and with Netgear devices likely configured to do the same, I feel better that this isn't just some random one off that happened to my devices.
Thanks
