DougDePew
Oct 20, 2021Aspirant
MK83 Lowers internet speed
So I have this lovely MK83 mesh setup, which seemed happy for a while. However, lately I have noticed that the speed (internet side) drops back to around 100MB, where the service is 400MB. If I reb...
DougDePew
As I noted, it is wired or wireless. Not an issue with that.
MR80, F/W 1.1.6.6_3.1.93
Spectrum E31T2V2
Satellites are eliminated from the equation. Wireless test is from within 10' of router.
No other wireless channel overlaps, but with the issue also on wired, not a concern again.
Oct 20, 2021Guru - Experienced User
Is Armor enabled by chance?
Has a factory reset and setup from scratch been performed since last update?
Spectrum E31T2V2
- DougDePewOct 20, 2021Aspirant
No Armor involved, and resets (2) have not had any impact.
- FURRYe38Oct 21, 2021Guru - Experienced User
What speeds do you see with a wired PC?
What wireless device are you speed testing with?
- DougDePewOct 21, 2021Aspirant
With a fresh router reboot, 430ish. Same as wireless after restart. At some random interval later, wired and wireless struggle to attain 100, usually high 80's. Fresh router restart, 400+ is back.
Speed tests performed with a phone, a tablet, 3 laptops. All matching results.
