Dakintosh
Jan 02, 2024Aspirant
MK93 (MR90) Ethernet Backhaul Not Working
Hello! I purchased an MK93S from BestBuy a couple days ago and I can't seem to get the ethernet backhaul to function to save my life. The router and satellites are all running Firmware Versio...
- Jan 04, 2024
I connected one of the satellites with a known good Cat6 patch cable from one of my server rooms and still nothing.
BUT
Last night I stumbled on a thread on Reddit from a few years ago where this person had a specific restart pattern to get the ethernet backhaul to be recognized. It seemed silly to me but I tried it and it worked.
Their steps:- Verify cable functionality
- Unplug satellite one
- Reboot main router using the reboot function in the GUI
- Unplug satellite two
- Reboot both satellites
- Reboot router one last time using the reboot function in the GUI
Voila - both showed as wired in the GUI.
Truly strange course of events but I am happy with the outcome!
Dakintosh
Jan 04, 2024Aspirant
BUT
Their steps:
Jan 04, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
