PtsD
Jan 14, 2025Aspirant
Mk93s --Ms90 satellites won't wirelessly connect to mr90
Night hawk tri-band mesh 6e system (mk93s). I cannot get the satellites to connect to the router. I tried the nighthawk app and routerlogin. I tried a reset of the modem. I tried redoing the router an...
Jan 14, 2025Guru - Experienced User
So if you factory reset both MR and all MS while having the MS in same room with the MR, After all as been factory reset on the MS first, then MR, give about 5 minutes and see if the MS auto connect the MRs default SSID name before you begin the setup wizard routine from and wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
MS should auto connect the MRs default SSID name after all has been factory reset. Press the reset button for 15 seconds on the MS first, then MR lastly. Give about 5 minutes for the MS to connect. Might do the MS one at a time.
