PtsD
Jan 14, 2025Aspirant
Mk93s --Ms90 satellites won't wirelessly connect to mr90
Night hawk tri-band mesh 6e system (mk93s). I cannot get the satellites to connect to the router. I tried the nighthawk app and routerlogin. I tried a reset of the modem. I tried redoing the router an...
Feb 05, 2025Guru - Experienced User
Any progress on this?
PtsD wrote:
Night hawk tri-band mesh 6e system (mk93s). I cannot get the satellites to connect to the router. I tried the nighthawk app and routerlogin. I tried a reset of the modem. I tried redoing the router and satellites firmware.
The satellites work only when connected via ethernet. The router works on its own just fine. I have searched the internet and did everything that seemed sensible. The only thing I haven't tried is disabling the armor protection the netgear forcibly turned on when I set up the mesh system (only just thought about this, will try later). I had a nighthawk p8000 with ex8000. The extender bricked so i am looking for a replacement for it/them.
Any other suggestions?
