MGPowell
Jan 06, 2022Guide
MR 60 Firmware Upgrade - Netgear App not recognising latest Firmware release
My MR60 is running current firmware of v1.0.6.116 and when I run the Nighthawk App it is confirming this is the latest version, even though I have been notified that v1.1.6.122 is the latest Any ...
- Jan 11, 2022
Yes thanks - plemens directed me to the other forum and I followed the manual updates, to complete on all devices... Thanks
Jan 06, 2022Guru - Experienced User
You can manually update. I recommend updating the satellites first and then the router.
MGPowell
Jan 06, 2022Guide
Ah OK , was hoping to avoid that but will give it a try...
- michaelkenwardJan 08, 2022Guru - Experienced User
Netgear makes life complicated with the layout of this place. To talk to users of the MR60 try the appropriate section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR CommunitiesSearch - NETGEAR Communities – MR60
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - FURRYe38Jan 10, 2022Guru - Experienced User
- MGPowellJan 11, 2022Guide
- plemansJan 11, 2022Guru - Experienced User
If it updated and works correctly, you can mark it as solved so others aren't trying to fix it.
Glad to hear it worked!
