MGPowell
Jan 06, 2022Guide
MR 60 Firmware Upgrade - Netgear App not recognising latest Firmware release
My MR60 is running current firmware of v1.0.6.116 and when I run the Nighthawk App it is confirming this is the latest version, even though I have been notified that v1.1.6.122 is the latest Any ...
- Jan 11, 2022
Yes thanks - plemens directed me to the other forum and I followed the manual updates, to complete on all devices... Thanks
Jan 10, 2022Guru - Experienced User
MGPowell
Jan 11, 2022Guide
- plemansJan 11, 2022Guru - Experienced User
If it updated and works correctly, you can mark it as solved so others aren't trying to fix it.
Glad to hear it worked!
