Paddles5's avatar
Paddles5
MR60 — Nighthawk Mesh WiFi 6 Router
my internet works great on 5.0 network,  I can find my 2.4 except my internet will not work
  • my mesh 60 system internet only works on the 5.0 and guest network but not the 2.4 ho do I fix that
    • FURRYe38's avatar
      Any updates or progress on this?
  • FURRYe38's avatar
    What brand and model devices are you using on the 2.4Ghz radio network?
    Is Smart Connected enabled or disabled?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
