BloodHunter90
Jan 10, 2021Aspirant
MR60 - Android Connection Issue
Hi, I have a Nighthawk Mesh WiFi 6 System, updated to latest firmware (V1.0.6.102_2.0.45). I cannot connect my Android TV Box to the WiFi 6 System. I can connect it to my phone using Hotspot...
Christian_R
Jan 14, 2021NETGEAR Employee Retired
Hello BloodHunter90,
Have you had a moment to get in contact with the TV Box manufacturer? You may try performing a factory reset on your Nighthawk mesh system and run through the setup assistant again.
Christian
BloodHunter90
Jan 18, 2021Aspirant
Hi Christian,
I have reached the TV box manufacturer and tried to reset and update it, but still no luck.
I will hard reset the mesh system and see if I have luck with this solution.
Thank you.
Best regards
Thank you.
Best regards
