ThreeAs
Feb 20, 2021Follower
MR60 - How do I split my wireless network into 2.4GHz and 5GHz?
A few weeks back I purchased Nighthawk MR60 for my house and am very pleased withh its functioning. It has both frequencies 2.4 and 5 GHz. When I installed the Skybell for my front door, it automatic...
in2ndo
Aug 06, 2021Apprentice
I’ve only used the MK63 for about a week and now have a MK83. The app is pretty much useless for anything custom.
I don’t recall if the 60 series has it. But the 83 does have the ability to separate the 2.4 from the 5G.
If the 60 has it. This is where you can check.
https://kb.netgear.com/000063027/Can-I-create-separate-2-4GHz-and-5GHz-SSIDs-on-my-Nighthawk-Tri-band-Mesh-WiFi-6-products
- Paul_D999Aug 12, 2021Aspirant
Hi @in2ndo and @FURRYe38 thank you for your help.
I have been away for a few days and finally got back to sort out my issue.
In the end to save time and effort I bought a cheap (£20) TPLink 2.4Ghz Wifi Access Point and plugged that in to my Broadband router. Within 5 minutes had it configured with a new SSID and had the IOT heater device connected and working. Not the most eloquent solution but saved me hours of time messing around.
Does make me think whether to keep or recommend the Netgear Mesh solution (colleagues & friends).
Once again thanks for your help and support it is always appreciated from a newbie.
- FURRYe38Aug 12, 2021Guru - Experienced User
Enjoy.
