ThreeAs
Feb 20, 2021Follower
MR60 - How do I split my wireless network into 2.4GHz and 5GHz?
A few weeks back I purchased Nighthawk MR60 for my house and am very pleased withh its functioning. It has both frequencies 2.4 and 5 GHz. When I installed the Skybell for my front door, it automatic...
wolf6
Aug 15, 2021Aspirant
Oddly enough, when I connect my 2.4GHz devices (23 of them) to my MR60 guest network, they all connect and operate at 2.4GHz with no problem. Not sure why, maybe guest network default is 2.4GHz.
TheBigRod
Aug 17, 2021Aspirant
I dug through my collection of old cell phones and found one that only connects to 2.4GHz networks. I had to install all the IOT apps onto the old phone (not easy when you're running 8GB memory!), and reconnected all of them to the MR60. I have visibility of all of them on my 5GHz devices now. Not the easiest workaround, but prevents you from having to set up a secondary 2.4GHz network and constantly connecting/reconnecting networks on your smartphone to control your IOT devices.
Still, for the MR60 to lack such a simple splitting option in it's firmware settings is a huge miss, IMO. They need to roll that one out, pronto.
