Mjb1971
Mar 19, 2022Aspirant
MR60 - MR1100 no internet connection
I have MR60 router with MR1100 providing internet connection thru GSM network. Every time we have a power outage, my network goes crazy and I believe the issue is with the MR60 communicating with th...
Mjb1971
Mar 20, 2022Aspirant
More details. Despite trying to change the WAN/Internet IP addressing, nothing ever "sticks."
Verified that DHCP is operating on my MR1100. This means the MR60 SHOULD be getting an IP, right?
- plemansMar 20, 2022Guru - Experienced User
You have both devices in router mode. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the mr1100 in modem only/pass through mode. This disables its routing functions.
2. Leave the mr1100 in router mode but put the mr60's IP address into its DMZ. This forwards the data to the mr60. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the mr60 into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
