jwp32765
Jul 18, 2021Aspirant
MR60 - MS60 Port Forwarding
I have an MR60 with two MS60 satellites. Everything was working correctly and until I created custome port forwarding rule. One port, one protocol (TCP) and one destination. I applied the rule, reboo...
Christian_R
Jul 21, 2021NETGEAR Employee Retired
Hello jwp32765,
A factory reset should wipe the rules out. Can you confirm that you are holding down on the reset button for 15+ seconds and running through the setup assistant again?
Christian
jwp32765
Jul 23, 2021Aspirant
Thank your for the reply.
The whole configuration was gone as expected. After making a couple of additions and changes the rules went invisble again. I frankly do not have time to be resetting the router and re-adding all my settings after every couple of changes. I appreciate the help.
