hsmith
May 26, 2022Tutor
MR60 - Not able to access Twitter?
I just purchased the nighthawk mesh and installed it. Works great. Newest firmware (1.1.6.124) uploaded today. But I cannot access Twitter. At all. I haven't found any other website with issues. It d...
hsmith
May 31, 2022Tutor
Modem is Comtrend VR-3060
The Armor and Traffic Meter are disabled, but I don't have a "circle" to turn on or off.
I've tried new DNS, I've enabled IPv6, etc.
Plugged, unplugged, rebooted, etc.
I'm on Windows 11 on a Microsoft Surface tablet. It loads an error. My husband is on a Chromebook and it loads perfectly every time. We're on the same network.
I've turned off all my browser extensions. I've tried Edge and Chrome. I can use my phone to access the app, so it's not a Twitter account issue.
I'm about to give up on this system. I'm a social media marketing student, I HAVE to have access to Twitter on a regular basis!
May 31, 2022Guru - Experienced User
The comtrend is a modem/router combo device. It causes a double nat. Usually isn't a major issue but it could be causing your problem.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- hsmithMay 31, 2022Tutor
The router function was never enabled on the modem. When it was installed the tech used our old (circa 2016? Maybe older?) Netgear router, which had been functioning well with the old cable internet we'd had. When we upgraded to faster internet with another company I wanted to upgrade our router and went with the MESH so it would reach areas in our house that were usually dead zones. While on the old Netgear router, with the ComTrend modem, I could access Twitter like normal.
- plemansJun 01, 2022Guru - Experienced User
did you check your comtrend or just trust that its in bridge? and that the bridge function is running appropriately?
- hsmithJun 01, 2022Tutor
I don't know how I would do that without connecting it to a device, but I don't have an ethernet port on my Surface or my husband's chromebook. It's not broadcasting any kind of wireless signal that I can find, so I'm sort of left to assume that all the router functions are disabled.
