drh841
May 21, 2024Aspirant
MR60 - Router blocking one device despite setup page showing the device is connected and allowed
Hi Model is Nighthawk MR60. firmware 1.1.7.134_2.0.65 I'm experiencing a problem where only one device on my network is not reaching the internet. The device in question is a MacBook Pro, 13-...
- May 21, 2024
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry a factory reset on the MK system and setup from scratch?
May 21, 2024Guru - Experienced User
- drh841May 21, 2024Aspirant
Thanks for the reply. Not quite sure where you are going with this. Two iPads and an iPhone without any trouble on the network therefore solution 1 doesn't seem to apply.
Solution 2 also doesn't seem to apply, did you mean to direct me to a factory reset of Nighthawk MR60? Didn't see the correct links.
- drh841May 29, 2024AspirantWell, I set up from the start again. Still not sure what the issue was but this seems to have fixed it. Would have preferred to know what the problem was and fixed that rather than scrap the whole thing, but it's all back up and running.
- FURRYe38May 30, 2024Guru - Experienced User
I agree. Many odd things can happen to routers mysteriously. Hard to narrow down or find the actual cause sometimes.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
