drh841
May 21, 2024Aspirant
MR60 - Router blocking one device despite setup page showing the device is connected and allowed
Hi Model is Nighthawk MR60. firmware 1.1.7.134_2.0.65 I'm experiencing a problem where only one device on my network is not reaching the internet. The device in question is a MacBook Pro, 13-...
- May 21, 2024
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry a factory reset on the MK system and setup from scratch?
May 21, 2024Guru - Experienced User
drh841
Thanks for the reply. Not quite sure where you are going with this. Two iPads and an iPhone without any trouble on the network therefore solution 1 doesn't seem to apply.
Solution 2 also doesn't seem to apply, did you mean to direct me to a factory reset of Nighthawk MR60? Didn't see the correct links.
- FURRYe38May 21, 2024Guru - Experienced User
Something to try.
Yes there is a PDF there that you can use to walk thru a factory reset of the MK system.- drh841May 21, 2024Aspirant
I'll look again. Note "novice" in the post. I have an MR60, not an MK... Hence my confusion.
- michaelkenwardMay 21, 2024Guru - Experienced User
