drh841
May 21, 2024Aspirant
MR60 - Router blocking one device despite setup page showing the device is connected and allowed
Hi Model is Nighthawk MR60. firmware 1.1.7.134_2.0.65 I'm experiencing a problem where only one device on my network is not reaching the internet. The device in question is a MacBook Pro, 13-...
- May 21, 2024
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry a factory reset on the MK system and setup from scratch?
drh841
Thanks for the reply. Not quite sure where you are going with this. Two iPads and an iPhone without any trouble on the network therefore solution 1 doesn't seem to apply.
Solution 2 also doesn't seem to apply, did you mean to direct me to a factory reset of Nighthawk MR60? Didn't see the correct links.
May 21, 2024Guru - Experienced User
Something to try.
Yes there is a PDF there that you can use to walk thru a factory reset of the MK system.
- drh841May 21, 2024Aspirant
I'll look again. Note "novice" in the post. I have an MR60, not an MK... Hence my confusion.
- michaelkenwardMay 21, 2024Guru - Experienced User
