rdt40ish
May 28, 2021Aspirant
MR60 - speedtest shows varying results - slow
All, I had recently bought the ORBI and was getting great results ... app showed speed test or 1.1 MPS/ downloads. Unfortunately, my decorator wife hated the look and it wouldnt fit into my media p...
rdt40ish
Thanks and yes my "media" cabinet is metal though i've had it standing open while i test this out. Simply interesting i get different speeds sitting in same spot. Also, because i briefly had Orbi, i know what is possible. ~60 MPS vs 1.1 GPS is a huge difference.
May 28, 2021Guru - Experienced User
You also put other numbers that you were hitting.
So the 60mbps, was that over 2.4ghz or 5ghz?
Were you connected to the router or the satellite?
what device were you testing on?
what orbi did you have?
Were you testing with the built in speedtest or the speedtest app (need to define for each result)
