Cyberchill
Apr 07, 2022Tutor
MR60 - Youtube slow to load
When I open youtube, there is a delay before the ad or content loads. This may be 15-30 seconds or more. This happens regardless of if it is a computer or a mobile device on the wifi network. When...
- Apr 07, 2022
that fibre is connected to some ONT.
What ONT is it?
Do you have IPv6 enabled?
Are you using netgear armor, parental controls?
Have you tried using a different dns from the stock one? you can try googles at 8.8.8.8 or 8.8.4.4
Apr 07, 2022Guru - Experienced User
- CyberchillApr 07, 2022Tutor
Running the latest: V1.1.6.122_2.0.58
I have FTH which goes straight into the Router. There is no modem.
Thanks!
- plemansApr 07, 2022Guru - Experienced User
What ONT is it?
- CyberchillApr 08, 2022Tutor
So I have no idea where the ONT is, or what model it is. Likely it is in a box near the curb. My provider is MetroNet, formerly Jaguar Communications. I will likely contact them to see if they have ideas as well. Essentially I have a Cat6 cable going into my NG and it is configured with PPPoE.
IPV6 is enabled with a 6to4 tunnel and auto everything after that.
I am not using Armor or Circle.
I'll change the DNS to see if that helps.
Thanks!
