Cyberchill
Apr 07, 2022Tutor
MR60 - Youtube slow to load
When I open youtube, there is a delay before the ad or content loads. This may be 15-30 seconds or more. This happens regardless of if it is a computer or a mobile device on the wifi network. When...
- Apr 07, 2022
that fibre is connected to some ONT.
What ONT is it?
Do you have IPv6 enabled?
Are you using netgear armor, parental controls?
Have you tried using a different dns from the stock one? you can try googles at 8.8.8.8 or 8.8.4.4
Apr 07, 2022Guru - Experienced User
Cyberchill
Apr 07, 2022Tutor
Running the latest: V1.1.6.122_2.0.58
I have FTH which goes straight into the Router. There is no modem.
Thanks!
- plemansApr 07, 2022Guru - Experienced User
What ONT is it?
- CyberchillApr 08, 2022Tutor
So I have no idea where the ONT is, or what model it is. Likely it is in a box near the curb. My provider is MetroNet, formerly Jaguar Communications. I will likely contact them to see if they have ideas as well. Essentially I have a Cat6 cable going into my NG and it is configured with PPPoE.
IPV6 is enabled with a 6to4 tunnel and auto everything after that.
I am not using Armor or Circle.
I'll change the DNS to see if that helps.
Thanks!
It was indeed the DNS setting. Once changing them to 8.8.8.8 and 8.8.4.4 it was like magic. Thank you!
