Cyberchill's avatar
Apr 07, 2022
MR60 - Youtube slow to load
When I open youtube, there is a delay before the ad or content loads.  This may be 15-30 seconds or more.  This happens regardless of if it is a computer or a mobile device on the wifi network.  When...
  • plemans's avatar
    Apr 07, 2022
    that fibre is connected to some ONT.
    What ONT is it?
    Do you have IPv6 enabled?
    Are you using netgear armor, parental controls?
    Have you tried using a different dns from the stock one? you can try googles at 8.8.8.8 or 8.8.4.4
