Cyberchill
Apr 07, 2022Tutor
MR60 - Youtube slow to load
When I open youtube, there is a delay before the ad or content loads. This may be 15-30 seconds or more. This happens regardless of if it is a computer or a mobile device on the wifi network. When...
- Apr 14, 2022
This turned out to be an issue with my ISP. In the past they required a PPPoE connection with userid/pwd. They changed my connection to not require a password and is just a DHCP connection. All good now!
Apr 14, 2022Guru - Experienced User
What devices are you using for youtube?
Cyberchill
Apr 14, 2022Tutor
- FURRYe38Apr 14, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
