TahoeBound
Nov 28, 2024Aspirant
MR60 & 2 MS60 satellites - reconnect issues after reboot
MR60 Mesh Web 6 with 2 MS60 satellites rebooted network - master and the 2 satellites all have the blue lights my laptop and printer are the two that I notice connect right back up to the network ...
- Nov 29, 2024
Thanks a lot for the response Michael.
Yep, I 'forgot' the network, rebooted then (attempt to) reconnect - no luck.
Weird that some devices would connect while others won't. (and this is with several power restarts on the MR60)
So, I went ahead and did a factory reset - interesting though, network actually came back up with my custom network name (and not the factory default) and all devices connected right back up.
Issue resolved (for whatever reason) - but, thanks again for your input.
michaelkenward
Nov 29, 2024Guru - Experienced User
looking at a WifiAnalyzer app - I see my network - very strong signal.issue is - the 2 cellphones will not reconnect nor will my SamSung Smart TV.
When you see something like that, it can be a good idea to start with the devices that won't connect.
Have you told the cellphones to forget the connection to the router and set up the connection from scratch?
Then there is this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Likewise the TV. (Is it connected to the wifi or wired?) Have you put that through it setup routine?
Just another user with time on their hands.
TahoeBound
Nov 29, 2024Aspirant
- michaelkenwardNov 29, 2024Guru - Experienced User
You expected these things to be logical?
Glad it worked out.
