TahoeBound's avatar
TahoeBound
MR60 & 2 MS60 satellites - reconnect issues after reboot
MR60 Mesh Web 6 with 2 MS60 satellites rebooted network - master and the 2 satellites all have the blue lights my laptop and printer are the two that I notice connect right back up to the network ...
  • TahoeBound's avatar
    TahoeBound
    Nov 29, 2024
    Thanks a lot for the response Michael.
    Yep, I 'forgot' the network, rebooted then (attempt to) reconnect - no luck.
    Weird that some devices would connect while others won't.  (and this is with several power restarts on the MR60)
    So, I went ahead and did a factory reset - interesting though, network actually came back up with my custom network name (and not the factory default) and all devices connected right back up.
    Issue resolved (for whatever reason) - but, thanks again for your input.
