Christian_R
Aug 25, 2020NETGEAR Employee Retired
MR60 / MS60 - Firmware Update v1.0.6.102
Hello Nighthawk Mesh Community,
There is a new firmware available for the MR60/MS60 to help address connectivity issues. We recommend updating to firmware version 1.0.6.102 if you are experienc...
DaveNeely
Aug 26, 2020Guide
Has anyone had issues with ethernet connectivity with the new firmware update? My new setup was working fine for several days, Nighthawk Mesh MR60 with 2 satelites. Router connected to a Netgear switch, which in turn has two other switches downstream. Combination of wireless and wired devices. All of sudden in the middle of the day all the ethernet devices stopped working, the computers can't get an IP address. Rebooted everything a million times, swapped cables etc no luck.
- knightz01Aug 26, 2020Apprentice
Same setup as you, switch at Router and two other unmanaged switches down wind, with v1.0.6.102 both WiFi clients and wired would disconnect, only putting router back to factory default would correct issue for me, so gave up and downgraded.
- DaveNeelyAug 26, 2020Guide
knightz01 wrote:Same setup as you, switch at Router and two other unmanaged switches down wind, with v1.0.6.102 both WiFi clients and wired would disconnect, only putting router back to factory default would correct issue for me, so gave up and downgraded.
Ah interesting, I just downgraded to the 1.0.4xxx version but I haven't done a factory reset yet. I'll try that, still having issues with downstream switches being able to communicate with the router and get an IP address. Since you downgraded and did a factory reset, has the issue returned?
