Christian_R
Aug 25, 2020NETGEAR Employee Retired
MR60 / MS60 - Firmware Update v1.0.6.102
Hello Nighthawk Mesh Community,
There is a new firmware available for the MR60/MS60 to help address connectivity issues. We recommend updating to firmware version 1.0.6.102 if you are experienc...
DaveNeely
Aug 27, 2020Guide
Thought I should close my loop for whomever might be reading this thread. After days of troubleshooting and pulling out what little hair I have left, I finally found my issue. It wasn't with the Nighthawk itself, it was with a new TP Link downstream switch I had installed at one of our computers. The timing of everything made it appear that this was unrelated, but after doing a lot of other things I finally had the notion to unplug every device from all my switches (I've actually got 4 on my network) and then plug each device in one by one and see if it caused any issues. I guess the bad device was somehow causing a loop, all the ports with cables plugged in when it was malfunctioning would blink together in unisom, not the normal erratic blinking when each port is processing traffic. So, thanks for the help and suggestions, and good luck to anyone who is struggling with these types of issues.
