Christian_R
Aug 25, 2020NETGEAR Employee Retired
MR60 / MS60 - Firmware Update v1.0.6.102
Hello Nighthawk Mesh Community,
There is a new firmware available for the MR60/MS60 to help address connectivity issues. We recommend updating to firmware version 1.0.6.102 if you are experienc...
knightz01
Aug 29, 2020Apprentice
Firmware Version 1.0.6.102 update
Disconnects
Day 1 – 27/08/2020
1) No problem
Day 2 – 28/08/2020
1) Echo show (17hrs) – had to manually reconnect.
2) Network Map – (17hrs) noticed that satellites are in series not the star connection, 1hr later shows back to star config.
Day 3 – 29/08/2020
1) 16:00 Red light at the front of MR, everything disconnected whilst eating dinner, 4 minutes later everything re-connected apart from 1 x echo spot, 1 x echo show & 3 x smoke detectors.
2) 17:15 PLEX will not run without buffering, Rebooted MR, red light showing for approx. 4 mins
(i) 32 x devices reconnected out of 37.
(ii) 3 x smoke detectors solely on the Guest network did not reconnect.
(iii) Ref (ii) Guest network is now unticked and disabled in settings.
Kev
