Christian_R
Aug 25, 2020NETGEAR Employee Retired
MR60 / MS60 - Firmware Update v1.0.6.102
Hello Nighthawk Mesh Community,
There is a new firmware available for the MR60/MS60 to help address connectivity issues. We recommend updating to firmware version 1.0.6.102 if you are experienc...
WildernessGuy
Sep 08, 2020Aspirant
This router is not working for me, so I have decided to return it. But I thought that I would offer my opinion that the problem may lie in the implementation of the S protocol. Because of the topology of my home, I often spend a significant portion of time in the overlap area between the router and the one satellite that I have deployed, and even spend a fair amount of time in an area that is almost exactly at the midpoint between the two; I seem to get the most network connection drops when I am in that overlap area. I think it's entirely possible that when a strong signal is present from both the router and the satellite, the S protocol implementation gets confused and switches between the two stations, which can take some time and it is possible that it gives up because it can't decide which station to connect to. It is conceivable that the thresholds for abandoning an existing connection to a station in favor of a new connection to a different station are not appropriately set and/or that the signal strength variability of the router is too great to properly assess the most appropriate station to connect to.
- Retired_MemberSep 17, 2020
Hello @Christian_R, do we have any update about this? any kind of new beta firmware?
I bought this on june 30th and im still unable to use it...
3 different firmwares...1 beta firmware...
2 support cases...
and yet we are like the beginning...
