Christian_R
Aug 25, 2020NETGEAR Employee Retired
MR60 / MS60 - Firmware Update v1.0.6.102
Hello Nighthawk Mesh Community,
There is a new firmware available for the MR60/MS60 to help address connectivity issues. We recommend updating to firmware version 1.0.6.102 if you are experienc...
Gwired
Dec 23, 2020Aspirant
Why isn't the MR60 in the recommended model list?
Anyway I am still experience many disconnects on multiple PC's (3) wherein it will switch to 2.4Ghz from 5Ghz frequently and then eventually completely disconnect on the 2.4Ghz. These PC's are less than 20 feet from the router. And I have just downgraded to 1.0.4.98.... hopefully this fixes it.... but 1.0.6.102 does not! And when this came on... was the cause of the disconnects but i didn't figure it out until now.
- me20201Jan 03, 2021Tutor
I'd like to love this router, but my home devices don't
I have the version 1.0.6.102 on MR and MSs.The only problem I am facing, at random times the LAN trafic device to device is blocked.
Let's say my TV and my phone are both connected wirelesly on 5GHz band on MR. At times I cannot ping the TV from phone
Messages like no route to host , host down, etc.
Need to mention that during all this time, the TV and Phone works well when speaking about connection to internet.
If i move around house and my Phone gets connected to a satellite, then LAN connectivty comes back.
It feels like the default LAN route that any router shall have is going hayware. This seems completely random and I cannot pinpoint to any external factor causing it.
I even tried to assign static IPs and Static routes toward those devices, with no difference in behavior.
This is a big issue for me as I have various streaming devices (chromecasts), to which I can or cannot stream to because of this. Or I need to climb floors to make it work.
Interestingly though - the printer which is also wireless on 2.4G has not exhibited this behavior yet but it may be because I am seldom printing, comparing with music streaming.
There is a another thread on community on this exact topic, but I wanted to chime in here as well.
Christian_R in case you have a suggestion please chime in.
I'd honestly say if I cannot get this fixed, this router will go back
- Retired_MemberFeb 03, 2021
Hello all,
I just wanted to tell you that last firmware seems to be more stable. However im using only the router (without the satelite).
But also, i want to share my final answer before i close the support case:Hello XXXX!
Im testing this one since saturday.
Is much more stable than before. However my computer got kicked from the network without any reason.
Although it happened once.
I have to update the satellite.
However i will not keep this device as is still not good enough...
Really a lot of missing options/configurations.
I cannot setup specific SSID for specific band, mobile devices are jumping from one band to the other...
I already went for another solution, much more flexible and stable than this one.
So, thanks for your support... this is my last repply as i will never use a netgear product again, and of course, i will never recommend it.
