jwoozy's avatar
jwoozy
Follower
Jul 05, 2021
MR60 / MS60 - Firmware Update v1.0.6.110 Keeps Cutting out every other hour
I have the NightHawk Mesh WiFi 6 system AX1800, and the latest firmware (1.0.6.110) update keeps disconnecting my devices from the wifi every other hour.
  • Did you maybe change something else after doing the update?
    When I did the update to the latets hotfix (1.0.6.112) on my MK60 the configuration of the router got corrupted. I had to do power cycle and reset to get it working reliable again. Reset means new setup, of course.
    If you consider making a reset and power cycle install the latest version first (if available for your router), otherwise you might have to do it twice.
    Chilli
    • County's avatar
      County
      Following on from updating to firmware update v1.0.6.112 (hotfix) after about a month I I now finding that the MS60's have started to drop out on a regular basis over the last two days. I am unsure if this could be heat related ad the temperature here in the UK is very warm currently, has anyone else had issues?
