DevendraS
Apr 27, 2022Aspirant
MR60 Address Reservation updates are lost after reboot !!
Hi There, I have a MR60 router with 2 MS60 satellites. Firmware was upgrade just today to V1.1.6.124_2.0.59 so I am not sure if that has caused the following issue. I need to have some 42 MAC a...
- Apr 29, 2022
"after firmware update"
I've had things go weird after firmware updates. I've read time and again that it's a best practice to factory reset after a router firmware update, then reconfigure your device as needed. Similar to BIOS updates. I assume because they don't test migrating all possible settings, but they do test if applying new settings from a reset state works well.
Some people mentioned doing a setting backup, then restore...but that seems like taking the same old (possibly bad/wrong) settings and reapplying them. So I tend to just manually configure things again if I try this step.
This is one reason I haven't tried to whitelist my devices as you seem to be doing. Yes it'd give a bit of extra protection from someone else using your network (unless they copy an existing MAC address), but I'd think a good wifi password + high WPA setting (3 or 2-AES) should protect you fairly well too. But I'm not an expert.
May 02, 2022Guru - Experienced User
Did you try a full factory reset and setup from scratch after the FW was updated on the MS and MR?
I recommend you back up the MRs configuration to file for safe keeping as well:
- DevendraSMay 05, 2022Aspirant
So the full factory reset and setup from scratch worked. It took me couple of hours to get all the settings back but had no other choice.
I am now able to change the settings and even after a restart I do not loose them. Pi-Hole is now my DNS ... no more ads !!
Thanks for all your help EternalStudent and FURRYe38
-Devendra
